Hi Dirtfan,
I know it has been a while since your post, I don't stop in here as much as I used to.
There are a few great places to get info on trike,
www.3wheelerworld.com and 3wheeler.org I would do a little forum searching as there is a ton of info there. Another great place for parts if you haven't discovered them yet is
www.dratv.comI didn't go for a OEM perfect restoration so I wasn't too concerned about being off a little on the color. I used a glass back epoxy for the frame, gray rattle can, and the red is a 2 part automotive paint with a 2 part clear over it. I can check the paint code for the red if you want, it was a code I found on the 3wheelerworld forum although it turned out to be a little lighter then OEM.
I can't help with parts and I have gotten rid of all my atc70 parts but a pair of footpegs. These are neat machines which I will probably end up with anotherone sometime, I would love to put a bigger motor in one and customize it.
