NYRiders.com
May 21, 2012, 06:51:05 PM *
Welcome, Guest. Please login or register.
Login with username, password and session length
News:
   Home   Help Login Register
Pages: [1]   Go Down
  Print
Author Topic: Arctic Cat Speedrack Rack Box  (Read 2912 times)
0 Members and 1 Guest are viewing this topic.
GreatWhiteHunter
Treat things the way a dog would. If you can't eat it or screw it, piss on it and walk away.
Global Moderator
Veteran
Offline Offline
Gender: Male
No wheel spacers required!
WWW
« on: November 15, 2008, 08:02:31 PM »
Purchased a rack box, finally, something I said I'd never do. Reason why you ask? This one is a little different. It's the Arctic Cat Speedrack model that can be fitted with a quick-release kit for mounting directly to the rack. This box is also a little smaller than most. Meaning that it will (hopefully) not be in the way when I need to move my butt off the seat toward the rear of the machine. We'll see how that works out...
Anywhoo, here's some pix of the box mounted.
This is toward the back of the box. Only two pins are needed to secure the box.
This is toward the front of the box, you can see the "J" hook that slips into the front speedrack mount.
Back hinge, notice that this pin can be removed for fast separation of the top and bottom of the box.
Front latch and hinge location. Depending on where the hinge pins are placed, this box could be opened forward or rearward.
If you'd like to see these pix a bit larger, go here and click on the mid sized images to get the full size. Warning, they"re quite large!
Things to do:
- There seems to be a bit of "slop" in the front "J" hook mount. I'd like to find a thick "o-ring" or similar item to take up that movement so that box isn't bouncing at all.
- Finish installing the seal kit. I put most of it in, the important parts, but there is a bit more that I'm not too sure I like. I'd like to see if I can find something a little more durable for the application before I just slap in what they sent me.
« Last Edit: November 15, 2008, 08:52:34 PM by GreatWhiteHunter » Logged
\'09 KTM 300 XC (his)
\'05 Bombardier Outlander 400 H.O. (hers)
\'05 RAM 2500 4x4 (red, of course)
\'06 Suzuki V-Strom DL1000K6 (ours)
\'01 Kawasaki KDX200 (she thinks it\'s hers)
\'10 Ski-Doo MXZ 600 X-RS
\'06 Ski-Doo MXZ-X 600 H.O. SDI (hers)
PJ
Administrator
Veteran
Offline Offline
Gender: Male
WWW
« Reply #1 on: November 16, 2008, 11:48:22 AM »
Very nice !
Cat has that rack mounting system perfect !
Logged
2009 Grizzly 700 EFI / EPS
2003 Grizzly 660
CatMan-do
NYR Friends
Seasoned Member
Offline Offline
Gender: Male
« Reply #2 on: November 16, 2008, 12:07:51 PM »
Looks good!2pins EZ on/off! wish they made a smaller hard box for the front. My rear bag has 8 straps on it, kind of pain to get on/off. Ordered the front 4" extension rack for mine so i can carry more stuff, chain saw, gas......got to start working on my sled trails soon, the clubs on the last day of hunting....LETS RIDE!!!!!
Logged
08 cat 700 efi
07 cat 500 jeepcat (sold)
05 cat Z570 Red
oriska-sno-drifters
nocatv
ocatv
GreatWhiteHunter
Global Moderator
Veteran
Offline Offline
Gender: Male
WWW
« Reply #3 on: November 16, 2008, 02:15:11 PM »
I'm thinking that the 8" rear extension might be next. I think there's enough room for small gas cans between the sides of the box and where the extensions will end up. Might be able to use the Kolpin 1.5 gallon cans in that space. They're not cheap, but if they fit well they may be worth the price.
From Montana Jack's website:
Al,
I have the chainsaw press (lock) that fits into the speedrack and I have to tell you it's worth every penny! The saw doesn't move around at all.
Logged
MIK6
NYR Friends
Member
Offline Offline
« Reply #4 on: November 16, 2008, 03:36:59 PM »
Nice addition Kev. Just dont put the chips and the pepsi in the same place  LOL
MIK6 / Mike
Logged
Pages: [1]   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
