February 05, 2012, 11:40:54 PM *
Author Topic: battery connettion question  (Read 856 times)
mixerdriver
« on: April 28, 2009, 06:44:43 PM »
took the can am out for a ride was running fine out of nowhere this thing died. had nothing no lights no winch no starter nothing an no dash lights either . sat there awhile saying wtf! tried to pull start it fired up for about 10 or 15 seconds so the tow strap came out . got home ben starts taking battery out , and the ground wire cam off the battery . saying wtf again. so ben holds the battery cable on it fires up. then he takes it off its stops running. ben  says the battery needs to be hook up for this to run. one wood think being this has a pull start it should run . or is there sumthing wrong with the charging system bad ?? thanks paul
Inside every older person is a younger person wondering, 'What the heck happened?'
JoeR
2009 KTM 300 XC-We
« Reply #1 on: April 28, 2009, 06:47:53 PM »
There are plenty of vehicles that need a battery connection to run.  I've been on a Polaris Sportsman that would die when it got a bad bround connection.  My Honda motorcycle will do the same thing.
Sounds like Ben fixed it.
Joe
\"You don\'t build a reputation on what you\'re going to do.\" Henry Ford
mixerdriver
« Reply #2 on: April 28, 2009, 07:02:10 PM »
thanks joe i was hopen jr.  was  right  Praise you rule ben  Praise
CatsJ35
« Reply #3 on: April 28, 2009, 08:21:05 PM »
yep some companies like honda, polaris and can am use the battery as another voltage regulator. If you run a polaris with no battery within a min or two you will fry your headlights and taillights.
Neverlift Stable=
    ATV\'s: 09 DS450XC, (2) 02 Prairie 650\\'s, 03 Prairie 800BBK, 01 Lakota, 2004 Outlander 400 HO, 1984 LT125, (2) 90 LT80\'s,
Sleds: Triples: 99 Mach Z \"Rockstar\", 00 Mach Z 800, Millenium Mach Z 800 #32, Twins: 1999 MXZ 670 HO, 03 Grand Touring 700 SE, 06 Mach Z 1000 SDI
Snotime
I have returned from the dark side. :)
« Reply #4 on: May 03, 2009, 12:46:35 AM »
Yep, all the above. The battery is part of the electrical circuit. The pull start is there in case the battery dies. The battery can be completely dead and it will still run with the pull start when connected but take it out or disconnect it and you're walking.
06 Polaris Sportsman 450
07 LG Commander 110
Dinli 50
05 Harley Sportster 883
08 Polaris IQ Shift 600
98 Yamaha V-Max 700
88 Yamaha Excel III
82 22' Crestliner 302 Ford/Merc
http://www.pulaski-boylstonsnow.com/
Phantom
No Training Wheels!
« Reply #5 on: May 04, 2009, 06:53:45 PM »
Run anything without a battery or a bad battery long enough and you will fry the stator from it constantly trying to charge the battery at a high rate. The regulator needs to "see" voltage in the battery to regulate the charge rate if there is no voltage it goes into high charge and eventually smokes the stator.
Home South Jersey / Camp Tug Hill
Member:
Southern Tug Hill Snow Riders
Turin Ridge Riders
Tri-County Sportsmen Motorcycle Club
Enduro - Hare Scramble - Dual Sport
'03 Suzuki DRZ400s Dual Sport (Mine)
94 Yamaha XT 225 (Wife's)
05 Yamaha Rage Sled (Mine)
'04 Polaris 600 Classic (Wife's)
Snotime
« Reply #6 on: May 04, 2009, 08:22:10 PM »
Eventually can be a very long time. My starter in my 91 Trail Boss was junk the entire time I owned it, probably 10 years or more. The battery was dead the entire time I owned it and the people that bought it are still roping it over and it's still going.
07 LG Commander 110
Dinli 50
98 Yamaha V-Max 700
88 Yamaha Excel III
Phantom
No Training Wheels!
« Reply #7 on: May 04, 2009, 08:42:02 PM »
I believe that system uses an old style magneto for spark and a separate charging/lighting coil(s) just like older sleds. (you can tell the difference by how the lights dim at idle)
The lower the output from a stator or alternator the less likely it is to fry from overloading it.
 Newer machines have much higher stator outputs to keep their lighting and electronics happy and also run the ignition system (and fuel injection if equipped) off the same stator and are more prone to fry sooner.
Member:
Turin Ridge Riders
