February 06, 2012, 12:05:40 AM *
Author Topic: 2001 Honda TRX350 4x4, with a loud transmission  (Read 1120 times)
Thefox
« on: September 19, 2009, 08:41:07 PM »
I have a friend with a 2001 Honda TRX350 4x4, very low hours and in nice shape.  He is the second owner and uses it very sparingly and is a gentle rider (it might have 100 hours on it).  He said it shifter hard and was very notchy, I adjusted the clutch and he said it was better but still notchy.  I took it out for a lap around the yard and sure enough it really clunky in and out of each gear.  It hits the gears fine but is very loud and well, not smooth.
Is there anything I can do to smooth out the shifting?
Dirt.....
1985 Honda ATC 350X
1984 Yamaha YTM 200 (in many pieces)
1984 Yamaha YT60 Tri-Zinger
Road....
2004 BMW R1150R
Right hand sholder....
1991 Tomos A3 Bullet
1980 Yamaha QT50
Thefox
« Reply #1 on: September 26, 2009, 10:12:47 AM »
Anyone?
Dirt.....
1985 Honda ATC 350X
Road....
2004 BMW R1150R
1980 Yamaha QT50
CatsJ35
« Reply #2 on: September 26, 2009, 07:49:38 PM »
Nope that's the way they are I've ridden several from almost new to rode hard and put away wet type owners and all have that  whack in each gear. I had the smoothest shifting by reving it up a lil higher and almost double clutching by holding the lever down and taping the gas quick and let the lever out as the motor is winding down. But like I said all the 350, 300 and 450 shaft driven 4x4 hondas I've rode all have the same clunking.
Neverlift Stable=
    ATV\'s: 09 DS450XC, (2) 02 Prairie 650\\'s, 03 Prairie 800BBK, 01 Lakota, 2004 Outlander 400 HO, 1984 LT125, (2) 90 LT80\'s,
Sleds: Triples: 99 Mach Z \"Rockstar\", 00 Mach Z 800, Millenium Mach Z 800 #32, Twins: 1999 MXZ 670 HO, 03 Grand Touring 700 SE, 06 Mach Z 1000 SDI
