NYRiders.com
February 08, 2012, 06:48:38 AM *
Welcome, Guest. Please login or register.
Login with username, password and session length
News:
   Home   Help Login Register
Pages: [1]   Go Down
  Print
Author Topic: F250 auto locking hubs  (Read 6388 times)
0 Members and 1 Guest are viewing this topic.
2008RenegadeX
NYR Friends
Seasoned Member
Offline Offline
Gender: Male
« on: November 07, 2009, 04:29:54 PM »
any one know where i can get some used parts for my Excursion maybe a good junk yard betwend Pulaski and Syracuse? i need one auto locking hub and i would rather now get it off of E Bay.
thanks...
Logged
2008 Renegade x
2001 GSXR 1000
1996 Formula III
JoeR
NYR Friends
Veteran
Offline Offline
Gender: Male
2009 KTM 300 XC-We
« Reply #1 on: November 07, 2009, 11:01:48 PM »
Got one that's not locking in now?  You might be able to get away with cleaning it up, unless it grinding and stripped out.
I checked on the Low Range problem.  It's not common on that truck, so we're going to have to check it when it happens.  We can see if the Transfer Case Module has any codes in it too.
Logged
\"You don\'t build a reputation on what you\'re going to do.\" Henry Ford
2008RenegadeX
NYR Friends
Seasoned Member
Offline Offline
Gender: Male
« Reply #2 on: November 08, 2009, 07:01:50 AM »
for the summer i have the guts out of the hub i cleaned it spotless but the problem is behind the rubber bladder that puts the truck in 4X4. there is build up of crap behind the rubber bladder little chunks of something. they are pinched between the rubber and the auto manual switch you turn by hand. those little chunks of crud will not let the plastic part go all the way to the free position, leaving it up about 1/16 of an inch up making the splines just contact each other and grind when in 2X4. so right now i have 4X4 that works fine and 2X4 that grinds. or i can lock the hubs in and just drive in 2X4 for the winter. that is what i did last winter but i would rather just fix it.
Logged
2008 Renegade x
2001 GSXR 1000
1996 Formula III
skippydoo
NYR Friends
Seasoned Member
Offline Offline
Gender: Male
I CAN-AM CAN YOU
« Reply #3 on: November 08, 2009, 08:51:27 AM »
try dutchersinc.com
Logged
MUD HOLE PATROL
Phantom
NYR Friends
Veteran
Offline Offline
Gender: Male
No Training Wheels!
WWW
« Reply #4 on: November 08, 2009, 05:31:54 PM »
F250 that won't go in/out of 4X4 or in-out of low could be a relay. There are two in the aux fuse relay box under the hood near the master cylinder.
Logged
Home South Jersey / Camp Tug Hill
Member:
Southern Tug Hill Snow Riders
Turin Ridge Riders
Tri-County Sportsmen Motorcycle Club
Enduro - Hare Scramble - Dual Sport
'03 Suzuki DRZ400s Dual Sport (Mine)
94 Yamaha XT 225 (Wife's)
05 Yamaha Rage Sled (Mine)
'04 Polaris 600 Classic (Wife's)
2008RenegadeX
NYR Friends
Seasoned Member
Offline Offline
Gender: Male
« Reply #5 on: November 08, 2009, 06:42:13 PM »
no that part works the one hub will not unlock if i take it all apart there is noting in there but the plastic part will not move back far enough to let the splines disengage.
Logged
2008 Renegade x
2001 GSXR 1000
1996 Formula III
Phantom
NYR Friends
Veteran
Offline Offline
Gender: Male
No Training Wheels!
WWW
« Reply #6 on: November 08, 2009, 07:44:45 PM »
The aluminum ring in the hub is worn... The part the plastic piece rides on. It's been a while since I messed with them but it is a part that you would be able to replace but Ford services the hubs "As a unit" and does not supply internal parts of the hub individually. Had the same problem with my '97 Ramger replaced the hubs with manual Warn hubs at 1/3 the price of ONE hub assembly from Ford.
I thought about having the worn part welded up and machined back down but decided it wasn't worth the trouble.
If you take both hubs apart and compare them (measure) you will find the problem with the side that no longer fully disengages.
You would think the plastic would wear before the aluminum but not so.
Logged
Member:
Turin Ridge Riders
Pages: [1]   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
