February 07, 2012, 07:27:14 PM *
Author Topic: Belt Squeal  (Read 848 times)
CatMan-do
« on: November 28, 2009, 10:40:08 AM »
last 4-5 times out the belt squealed a little, just a little chirp but never heard that be for. is that something i should look into or let it go. about 850 miles on it and it was up to temp when it chirped. what do you think?
08 cat 700 efi
07 cat 500 jeepcat (sold)
05 cat Z570 Red
oriska-sno-drifters
nocatv
ocatv
CatsJ35
« Reply #1 on: November 30, 2009, 12:09:55 AM »
What size and type (single/twin) do you have? Sounds like just belt loosening up. time to  pull a shim out of the secondary. If you have the kawasaki set-up not hard to do and they sell a cpl different thickness shims to get the perfect deflection. Mine normally chirps a lil bit but I keep her a lil on the tight side. Also could of gotten wet??
Neverlift Stable=
    ATV\'s: 09 DS450XC, (2) 02 Prairie 650\\'s, 03 Prairie 800BBK, 01 Lakota, 2004 Outlander 400 HO, 1984 LT125, (2) 90 LT80\'s,
Sleds: Triples: 99 Mach Z \"Rockstar\", 00 Mach Z 800, Millenium Mach Z 800 #32, Twins: 1999 MXZ 670 HO, 03 Grand Touring 700 SE, 06 Mach Z 1000 SDI
CatMan-do
« Reply #2 on: November 30, 2009, 09:36:02 AM »
its a 08 700 efi. does from a dead stop just a little, one time a ride..not to worried about it , going to take it apart this winter and send my primary out for some work..
08 cat 700 efi
05 cat Z570 Red
oriska-sno-drifters
nocatv
ocatv
« Reply #3 on: December 01, 2009, 09:47:34 AM »
Mine does it, has since it was new. Replaced the belt at 2k and was told the orig had nothing wrong with it. Makes a nice spare now.
Ride it like you stole it!
CatMan-do
« Reply #4 on: December 01, 2009, 10:35:11 AM »
Well thats good to hear..did not want Russ to tow me  home with his popo..would never hear the end of that LOL
08 cat 700 efi
05 cat Z570 Red
oriska-sno-drifters
nocatv
ocatv
