NYRiders.com
February 08, 2012, 06:40:22 AM *
Welcome, Guest. Please login or register.
Login with username, password and session length
News:
   Home   Help Login Register
Pages: [1]   Go Down
  Print
Author Topic: Removing Ball Joint Housing  (Read 623 times)
0 Members and 1 Guest are viewing this topic.
Snotime
NYR Friends
Seasoned Member
Offline Offline
Gender: Male
I have returned from the dark side. :)
« on: March 19, 2010, 06:48:14 PM »
Anyone have any suggestions on how to get a ball joint housing out of a Polaris strut?
Logged
06 Polaris Sportsman 450
07 LG Commander 110
Dinli 50
05 Harley Sportster 883
08 Polaris IQ Shift 600
98 Yamaha V-Max 700
88 Yamaha Excel III
82 22' Crestliner 302 Ford/Merc
http://www.pulaski-boylstonsnow.com/
PJ
Administrator
Veteran
Offline Offline
Gender: Male
WWW
« Reply #1 on: March 19, 2010, 07:00:54 PM »
Yessir....
Done many of them....
Clean the bottom of the strut very good, there are 2 recessed Allen screws you need to remove and a plate that retains the ball joint.
Take a wrench that barely goes over the stud... Box end of course.. put it on there, put a washer and the nut back on.... heat up the bottom of the strut housing with a propane torch evenly all the way around the bottom... get it hot and then put pressure on the wrench pushing it down... if it doesn't slide out then use a hammer and tap on the wrench... it should come right out, if it doesn't, hit it harder and keep the strut heated up around the bottom...
Reinstalling.... take the new one and stick it in your freezer for a couple hours minimum... heat the bottom of the strut again.... install ball joint once bottom of strut is good and hot and ball joint is frozen...
The aluminum will expand at a rate faster than the steel in the ball joint will.
All of this can be done with the strut on the machine..
You can do it this way... or you can buy the tool from Polaris...
Hope this helps...
By the way... I stock those ball joints here in my garage for friends who have Poo's... lol...
If you have any problems call me, you have my # still I think, if not its in the contact forum here on the board...
Pj
Logged
2009 Grizzly 700 EFI / EPS
2003 Grizzly 660
PJ
Administrator
Veteran
Offline Offline
Gender: Male
WWW
« Reply #2 on: March 19, 2010, 07:04:23 PM »
I should mention that is the way to do it if the stud isn't already out of the joint.
If it is... its a bit harder... but it can be done.
Call me on that one, its a lot to type... lol....
Logged
2003 Grizzly 660
PJ
Administrator
Veteran
Offline Offline
Gender: Male
WWW
« Reply #3 on: March 19, 2010, 07:38:38 PM »
Here is one on the lift getting ball joints...
Logged
2003 Grizzly 660
Snotime
NYR Friends
Seasoned Member
Offline Offline
Gender: Male
« Reply #4 on: March 21, 2010, 11:50:48 AM »
Yep, the whole stud pulled out....about a half mile behind my house in the woods. It was a long hike out and a long hike back in carrying a tool box!
It looked something like this....
Here's a rear view. Home was straight ahead that way!
Logged
07 LG Commander 110
Dinli 50
98 Yamaha V-Max 700
88 Yamaha Excel III
Pages: [1]   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
