February 05, 2012, 11:47:24 PM
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News
Home
Help
Login
Register
Simple..... If you ride it, lets talk about it here.
ATV
Arctic Cat
front diff leak
Pages: [
1
Go Down
« previous
next »
Author
Topic: front diff leak (Read 836 times)
CatMan-do
Offline
Gender:
front diff leak
on:
March 20, 2010, 10:56:04 AM »
the jeepcats front diff leaks where the drive shaft goes into the diff. has anybody changed this seal? is it a PITA to change?
08 cat 700 efi
07 cat 500 jeepcat (sold)
05 cat Z570 Red
oriska-sno-drifters
nocatv
ocatv
rapidrobert
Offline
Gender:
Re: front diff leak
Reply #1 on:
March 20, 2010, 10:18:28 PM »
I have my front differential out of my 650v2 rite now for resealing.
You will have to pull out the differential.
On the scale from 1 to 10 I would say that the job would rank about a 7 on the PITA Scale.
You will need to order the o-rings on the 4x4 actuator because they will be swelled out of shape and will not be able to be reused.
you will need 2 axle seals and input seal and input housing gasket. My 650v2 has a snap ring that has to be taken off after you un
bolt the housing off the differential to get the input shaft out were the seal is leaking.
before I went to the trouble of this repair I would make sure that the vent is clear and open for the front differential, all-so make sure that the fluid is not contaminated with water
this will make the seals leak.
All-so some of the cat wheelers were over filled with to much fluid at the factory and it caused the seals to leak.
Before i did any thing I would change the front differential fluid and do not overfill it. fill it slow with the check plug out until you only get a drip out of the check plug then stop filling. It holds around 8 oz. of 80w90 gear oil . Then I would clean it off and ride it and recheck it.
Then if it still leaks, I would order the parts and schedule the surgery. Good luck Rapidrobert...
02 Arctic Cat Panther 570 2up
09 Arctic Cat F8 LXR
A bad day on the trail is better than a good day at work!
CatMan-do
Offline
Gender:
Re: front diff leak
Reply #2 on:
March 21, 2010, 09:40:05 AM »
Thanks for the info..changed the dif fluid 3 times on the 500 the same way using the level hole, 32oz bottle did f/r with 18oz left so thats 7 oz per dif. the book said Front 9.3 R 8.5 ?
any way over on Arcticchat they said to take the skid plate off ,unbolt the dif and move it forward should be able to get the shaft out that way ? will try that first and see. will let you know how it worked out
08 cat 700 efi
05 cat Z570 Red
oriska-sno-drifters
nocatv
ocatv
rapidrobert
Offline
Gender:
Re: front diff leak
Reply #3 on:
March 21, 2010, 08:38:00 PM »
Here is the link to the arctic cat atv service manual it may help you out.
http://www.mymowerparts.com/pdf/Arctic_Cat_ATV_Repair_and_Service_Manuals/
Rapidrobert...
CatMan-do
Offline
Gender:
Re: front diff leak
Reply #4 on:
March 21, 2010, 08:49:13 PM »
I think I have that...some place ... on here thanks
08 cat 700 efi
05 cat Z570 Red
oriska-sno-drifters
nocatv
ocatv
CatMan-do
Offline
Gender:
Re: front diff leak
Reply #5 on:
April 06, 2010, 08:43:47 AM »
theres two clamps on the drive shaft boot, how do I get them off with out tearing up the boot? can those clamps be used again?
08 cat 700 efi
05 cat Z570 Red
oriska-sno-drifters
nocatv
ocatv
Pages: [
1
Go Up
« previous
next »
Please select a destination:
=> ATV
===> Arctic Cat
===> Bombardier / Can-Am
===> Honda
===> Kawasaki
===> Polaris
===> Suzuki
===> Yamaha
===> All Other's
===> Tire Talk
===> Accessories
=> 3 Wheelers
=> Motorcycle
=> Dirt Bike / Enduro
=> Snowmobile
===> Trail Conditions and rider reports
=> Racing
Water Cooler
=> NYR NEWS
=> Water Cooler
Tech Corner
=> Tech Corner
===> Reviews
===> How-To's
Tow Vehicles and Trailers
=> Trucks
=> Trailers
CLASSIFIEDS
=> For Sale
===> ATVs
===> 3 Wheelers
===> Snowmobiles
===> Motorcycles
===> Dirt Bike / Enduro
===> Helmets / Riding Gear (clothing / protective wear)
===> Parts
===> Accessories
===> Tires and Rims
===> Trucks / Tow vehicles / Campers
===> Trailers (open and enclosed)
=> Want to Buy
=> Anything for sale
=> Barter / trade
=> Dealer Review
Pictures, Videos and Web Cams
=> Pictures and Videos
=> Web Cams
=> Image Testing
Announcements, Site Questions, Rules, Suggestions
=> Frequently Asked Questions
=> Site Comments
Loading...
