NYRiders.com
February 07, 2012, 09:06:37 PM *
Welcome, Guest. Please login or register.
Login with username, password and session length
News:
   Home   Help Login Register
Pages: [1]   Go Down
  Print
Author Topic: May 15th party  (Read 1594 times)
0 Members and 1 Guest are viewing this topic.
captgriz
NYR Friends
Seasoned Member
Offline Offline
« on: April 30, 2010, 05:04:49 PM »
  Hi, everyone is invited to the Edge Hotel in Lyons Falls for a groomer party.  We intend to remove and store the tracks and try to get a idea of what is wrong with our engine.  10am is our starting time and I can't promise any food or beverage, just a good time.  Turin Ridge Riders,,,,,
Logged
JoeR
NYR Friends
Veteran
Offline Offline
Gender: Male
2009 KTM 300 XC-We
« Reply #1 on: April 30, 2010, 06:36:34 PM »
What kind of problem, and what kind of engine?
Logged
\"You don\'t build a reputation on what you\'re going to do.\" Henry Ford
captgriz
NYR Friends
Seasoned Member
Offline Offline
« Reply #2 on: May 02, 2010, 05:24:12 PM »
  Engine is Mercedes Bentz V-6 420 series, last year we were using oil and antifreeze and found 2 cylinders with bad O-rings and sleeves, we had a pretty good winter and then the problem came up again.  I'm thinking of all 6 cylinders, O-rings whatever, bearings because of the anti-freeze leak, we have a complete engine minus tubro but I understand it was a oil leaker also,,,,Dick
Logged
himiler
NYR Friends
Veteran
Offline Offline
« Reply #3 on: May 02, 2010, 10:28:12 PM »
 I will plan on being there ,at least in the 1st half of the day..  Have some projects at camp.
Logged
JoeR
NYR Friends
Veteran
Offline Offline
Gender: Male
2009 KTM 300 XC-We
« Reply #4 on: May 02, 2010, 11:34:41 PM »
A 420 Series MBE is not an engine I'm familiar with...but I've pulled a wrench or two on a diesel.  Out of curiosity, when you found leaky liners did you drop the oil pan and see that you had a coolant leak at the bottom of the liners?  If so, you're probably right about needing to replace them all this time.
I recommend to investigate the oil and antifreeze consumption as separate issues.
My 2 cents (actual street value)
Joe
Logged
himiler
NYR Friends
Veteran
Offline Offline
« Reply #5 on: May 10, 2010, 07:32:56 AM »
                Just a reminder for those of you that can make it! The same faces are always there,would be good to see some new help also.
Logged
lonerider
Member
Offline Offline
Gender: Female
« Reply #6 on: May 10, 2010, 02:12:12 PM »
Hey Dick if Im up this weekend maybe I will swing by with some beverages and snacks.
Logged
WOLFNY
Member
Offline Offline
« Reply #7 on: May 10, 2010, 02:19:16 PM »
HI EVERYONE 8:30 OR 9:00 IS OUR STARTING IS GOOD FOR ALL BAHAHAHAHA
Logged
himiler
NYR Friends
Veteran
Offline Offline
« Reply #8 on: May 10, 2010, 02:24:06 PM »
Beverages are always welcome!!!
Logged
lonerider
Member
Offline Offline
Gender: Female
« Reply #9 on: May 10, 2010, 03:25:57 PM »
Coffee right?
Logged
himiler
NYR Friends
Veteran
Offline Offline
« Reply #10 on: May 10, 2010, 03:29:54 PM »
Coffee right?
  Yes  Caffee !!
Logged
himiler
NYR Friends
Veteran
Offline Offline
« Reply #11 on: May 12, 2010, 04:46:19 PM »
   Come on,not many volunteers here.  Alot of complaining all year during sledding season but not much help when the chance to showup and produce some results!!!!
Logged
JoeR
NYR Friends
Veteran
Offline Offline
Gender: Male
2009 KTM 300 XC-We
« Reply #12 on: May 12, 2010, 06:28:03 PM »
Sorry buddy. I'm in NYC/NJ/Baltimore area for the next 2 weeks.  No riding or anything for me for a while.  It's my busy season for the next 2 months.
Joe
Logged
Pages: [1]   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
