May 22, 2012, 12:58:14 PM *
Author Topic: can't get rear axle out  (Read 1250 times)
CatMan-do
« on: June 05, 2011, 01:54:29 PM »
can't get the axle out, pushing it in then hard yank, had a 4' slide hammer on it till it's almost falling off the jack stands
thinking about pulling the outher axle out and putting a rod/bar and trying it from the outher side if I can get that one out!
what do you think?
08 cat 700 efi
07 cat 500 jeepcat (sold)
05 cat Z570 Red
oriska-sno-drifters
nocatv
ocatv
CatMan-do
« Reply #1 on: June 10, 2011, 05:24:04 PM »
well got them out. my bud Russ came up to help, couldn't get them out...had some beers...looked around the barn and he came ou with this...home made axle puller...LMAO...got them both out.
08 cat 700 efi
05 cat Z570 Red
oriska-sno-drifters
nocatv
ocatv
CatGoneDoo
Polaris RZR
« Reply #2 on: June 10, 2011, 06:03:27 PM »
Is that a Snap-on logo I see?
« Reply #3 on: June 10, 2011, 08:07:17 PM »
I know I'm a little late, but back when I had a quad I would leave the castle nut on and just drop the a-arms from the machine. Then I could use the combined weight of the spindle/hub and a-arms to pull the axles out. Worked like a charm. :-)
CatMan-do
« Reply #4 on: June 10, 2011, 08:54:56 PM »
did you sell your quad?
08 cat 700 efi
05 cat Z570 Red
oriska-sno-drifters
nocatv
ocatv
« Reply #5 on: June 10, 2011, 09:14:55 PM »
I did.
rapidrobert
« Reply #6 on: June 18, 2011, 01:56:17 AM »
Here is the trick to getting out any captured snap ring cv joint housing.
As you apply slight outward pressure take a air hammer with a round hammer bit and rattle the cv housing on the side at a 90 degree angle to the cv housing and the cv housing will fall out like butter.
The outward pressure with the rattleing from the air hammer will compress the ring and Walla the housing pops out.
Rapidrobert...
04 Arctic Cat Panther 800 efi 2up
09 Arctic Cat F8 LXR
09 ranger RZR 170
2012 ranger RZR 800
A bad day on the trail is better than a good day at work!
