February 05, 2012, 11:30:56 PM *
Author Topic: Kawasaki bruteforce resetting belt light  (Read 7010 times)
tkmoto
Guest
« on: February 24, 2007, 09:14:53 AM »
I couldnt find it on this site so i figure i post how to reset your belt light on the Kawasaki bruteforce.
To reset, turn ignition off and pull cvt cover. Put switch inside cover back into "on" postion. Remove seat and disconnect the 2 connectors grey and black and reverse them. They are located if sitting on quad in right rear corner. The grey one is not connected to anything, it's just a reset plug. Grey into black and black into grey. On top of the CVT cover is a black connector that goes to the switch inside the cover, disconnect that at this time. With the 2 still reversed and the black one disconnected, turn the key to the on, but don't start the quad. Observe the belt light. When it stops flashing really fast and starts flashing slow, the belt light is reset. Turn key off, and put the 2 connectors under the seat back to their original connectors and plug the connector switch for the CVT back in. Your done
« Reply #1 on: February 24, 2007, 01:14:38 PM »
Good info to have.
I wonder if it is the same procedure for my V-Force, not that the belt light is on yet......
Pj
Adirondack Man
« Reply #2 on: February 24, 2007, 03:50:35 PM »
PJ,
I am trying to remember, but I think that it is the same for your V Force.  The only thing is that your reset connectors are not in the rear.  They are under the right side, just above the CVT cover, by the fuel shutoff.  I know that the reset procedure for the V Force, and the Prairie, are over on kawieriders and nyroc's site.  Still, I think it is just as TK said.
Growing old is mandatory.  Growing up is optional!
GEARSLAYER
Guest
« Reply #3 on: February 25, 2007, 09:05:23 AM »
It's about  Praise BRUTECENTRAL  Post Whore
Adirondack Man
« Reply #4 on: February 25, 2007, 11:57:14 AM »
Gearslayer,
You are too funny!  :D  Are you sure that the belt lite reset for the Brute Force is the same as for the V-Force?  I know that I absolutely did not have to remove the seat on my Prairie when I did my 100 hour belt lite reset.
